Pioneer DEH-P860MP
1meanGSX
52
Sep 6, 2005
Bremerton, Washington
Hey I was wondering if any of you guys have a Pioneer DEH-P860MP installed and how you like them. Also if anybody has any pictures of them in a 2g please post them. Thanks
I'll be getting the Pioneer 8600MP end of this month. If you want I'll take some pics and post them. It is the same thing as the 860MP which is Pioneer's Premier model. I have Alpine 6x9s and Type S components in the car right now.
That would be awesome if you get pics. I am definately getting the 860MP but I just want to see how it looks in a 2g. Derek
You forgot the cool specs on the 8600.
» detachable, motorized face
» multicolor Organic EL display
» customizable display
» plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA files)
» 24-bit Burr-Brown D/A converter
» Supertuner IIID
» 18 FM/6 AM presets
» CD Text
» disc naming
» 13-band equalizer (50, 80, 125, 200, 315, 500, 800, 1250, 2000, 3150, 5000, 8000, 12500 Hz)
» BMX digital processing (for improved sound from MP3 and WMA files)
» Auto EQ (uses an included microphone and the 13-band equalizer to adjust receiver output to your vehicle's acoustics)
» Easy EQ (5 preset and 2 user-adjustable EQ curves)
» Automatic Sound Levelizer (adjusts receiver's volume automatically to compensate for changes in road noise levels)
» BBE sound processing
» XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
» CD changer controls
» built-in high-pass (speaker/preamp outputs) and low-pass (preamp outs only) filters
» 4-volt front, rear, and subwoofer preamp outputs
» optional auxiliary input
» clock
» wireless remote
» 22 watts RMS/50 peak x 4 channels
» CD frequency response 5-20,000 Hz
» CD signal-to-noise ratio 100 dB
» FM sensitivity 8 dBf
» warranty: 1 year
I believe the 860 has the same specs but has Premier on the front instead of the 8600's Pioneer and has higher volt preamp outputs. Reviews on the 8600 can be found here http://www.crutchfield.com/S-zkMj46aXRAd/cgi-bin/ProdView.asp?i=130DEHP860
I still don't know what color they are. The pic here it looks dark silver
And the pic here, it looks almost black.
Hey thanks for all the specs, I should have posted that up. Also the Premier version has 6.5v preouts and a couple of other minor things, nothing to major. But man it is a sexy deck, I just got done playing with one and wow it has more settings and the sound quality with burr brown processors is out of this world. Seriosly the deck power sounds as good as some 4ch amps. I will have one by the end of this month hopefully. Derek
I was also considering this unit. Which of the 2 pictures above more accurately depicts the color?
The darker looking one is from ebay. The lighter on is from the Crutchfield archives, it might be an older model. I say the darker one SHOULD be the unit.
4 volt preouts? That sucks, the newer eclipses coming out have if you can beleive it, 8V pre-out. Check out the CD5000. The rest of the eclipse line has 5volt.
Actually the premier version is 6.5v and the eclipse is not if any nicer than the Pioneer, I played with both at Car Toys and I wasnt real impressed with the eclipse. They are both good decks but I think I am sold on the Pioneer.
No offense, but we hear that a lot selling and installing car audio. The speakers or unit may sound completely different to us, but thats because we are more tuned into it with more experience. The average person it is very hard for them to hear the difference.
Well, I just went online and bought the Pioneer Premier DEH-P860MP instead of the regular Pioneer DEH-P8600MP. For some reason the Premier was cheaper than the regular Pioneer. I'll post some pics after I get it and install it.
This is what it has:
Supertuner
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
CD Player
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Track Title List
CD Text CD Text
BMX Digital Enhancement
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Folder 253
Max File # per Disc 65,535
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9
WMA Bit Rate 48~192kbps, VBR
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.0; WMA
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search File and Folder
IP-Bus System Expandability
IP-Bus System Control
XM Radio Ready Yes
Sirius Radio Ready Yes (External)
iPod Adapter Ready Yes (External)
Multi-CD Control
DVD Control
TV Tuner Control
Built-in Auxiliary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Motorization Auto Slide Motorized
Display Type Multicolor Organic EL (OEL)
Dot Matrix OEL Size 192 x 48 (16 color)
Soft Key Operation Mode
Customizable Screensavers Update by CD-R
Screensaver Studio website www.pioneer.co.jp/car/pclink3a/
Screensaver Movies 2 (Great Barrier Reef, Night Cruising)
Background Animations 4
Background Pictures 5
Spectrum Analyzers 2
Level Indicators 2
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer 13-band Graphic
Equalizer Presets 5
User Equalizer Settings 2
Loudness Yes
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
BBE Digital
Automatic Sound Levelizer (ASL)
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network 3-Way Crossover
PRO Mode
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading) or PRO Mode (High, Mid, Low)
Preout Voltage & Impedance Hi-Volt (6.5V), 100 ohm
General Features
Remote Control 10-Key
Wired Remote Input
Cellular Mute
Detachable Face Security
Face Case (Included)
Warranty 2 Year
Premier Service and Installation
Yes I agree D Eclipse, but I am the type that plays with something numerous times and listens to many different setups and take into account the ease of funcionality. I have listened to almost every deck in the last 2 months and you can tell a difference between some but when you get to say the Pioneer 860mp or 960mp or the Alpine or Eclipse decks it starts to get very hard to distingiush differences on the higher end products. I believe for the price and performance the 860mp is one of the best decks right now. D Eclipse I am jealous you have that deck before me :thumb: , please tell me how you like it. I have about 2 more weeks and I will have one.
Yes I agree D Eclipse, but I am the type that plays with something numerous times and listens to many different setups and take into account the ease of funcionality. I have listened to almost every deck in the last 2 months and you can tell a difference between some but when you get to say the Pioneer 860mp or 960mp or the Alpine or Eclipse decks it starts to get very hard to distingiush differences on the higher end products. I believe for the price and performance the 860mp is one of the best decks right now. DGajre I am jealous you have that deck before me :thumb: , please tell me how you like it. I have about 2 more weeks and I will have one :rocks:
1meanGSX said:
D Eclipse I am jealous you have that deck before me :thumb: , please tell me how you like it. I have about 2 more weeks and I will have one :rocks:
DGajre777 not D Eclipse. ;)
I let you know how I like it. I have Alpine crossovers sitting under the CD player for my Alpine Type S components and I have Type S 6x9s in the back, It should sound sweet. :D I have a write up in the Tech Guide on installing tweeters in the stock 3 1/2" speaker location if you are interested in doing that.
Oh sorry about that, late last night was tired. But yea I have already got MB Quart components I need to install and I just got done looking at the dash tweeter how to. I am waiting on the 6x9 brackets so I can 6.5 components in those too. But let me know how you like the 860, it should be fantastic. Derek
I got some night shots, here you go.
I decided to get the installation kit because I have my Alpine Type S crossovers mounted under the CD player. I made a plate out of some black plastic that I got from ebay and screwed it under the kit.
Haha..next time you take night shots, turn the flash off!
