Passenger "safety" handle chicken grip
Pull the sides towards you, slide it towards the inside and it will reveal 2 bolts. You can't just yank on it to take it off, it is the called the "oh shit" handle for a reason.
Pardon the crappy image, but you get the point.
^^ Confirmed. You gotta pull the end of that rubber trim piece outwards. Once you get it started, just keep on pulling. The underside of the trim reaches pretty far underneath the bracket that the bolt is holding onto but it's really not hard to get those end pieces off to expose the bolt.
Try hiking your skirt up right before you attempt it. ;)
How do I remover the bar I dont know what you call it the Oh My Sh*T Handle on the passenger side. I tried with a screwdriver but it started ripping the rubber apart. I need to remove it to access sunroof cable.
you slide the rubber ends in towards the handle and there's two bolts
Those rubber covers have to be removed after you've pulled the handle out- it has an in and an out setting, sort of. You should be able to just lift them up and get at the screws.
