FirstDSMTimer
- 75
- 0
- Jun 26, 2011
Baltimore,
Maryland
am parting the entire car im just done working on it and need the money for another car.The car has been sitting for a long time so most parts are brand new just installed. The car does run and in still together minus the tb is off and a head light is out i tired to sell as a whole but will never make my money back that why if you have a good offer for the whole thing i will think about it.
dsmlink 3v lite with cable software and 95 eprom ecu $650
Mitsubishi evo 3 turbo fresh rebuild with etrader gregs rebuild kit come with 2g exhaust manifold and 1g o2 housing $350
full 2g awd exhaust witch includes brand new 3" megan racing dp with o2 bung, vibrant 3" high flow ceramic cat with used apexi n1 catback $500
2.5"short route piping with front mount $250
greddy type s bov $100
seimens and delka 750cc injectors $150
stock 450cc injectors $75
2g manifold hairline cracks no leaks $40
walbro 255lph fuel pump i just installed will remove $75
walbro 190lph removed to install 255 $40
1g intake manifold with egr block off plate $50
1g nt 63mm tb with new shaft seals and biss screw o-ring$65
1g coil pack $45
2gb headlights clear no fog $80
complete head block and cams for $offer
6 bolt stage 5 slowboy racing head stamped sbr105 $offer
hks 272 cams $offer
stock 6 bolt block$offer
95 awd transmission with a chip out where the shift fork goes in no problem with trans at all new redline mt90 in it $offer
brand new exedy stage 3 clutch with pressure plate $300
act flywheel $150
transfer case $250
power steering pump $40
force performance 4" intake $65
2g maf $50
3g eclipse wheels with fuzion tires 90% $250 plus stock wheels
3 pod a pillar $30
greddy exhaust temp gauge no wires or plug $30
apexi tt pen style plus plug and play harness $40
stock radiator with both fans $75
new iac $50
1g tps $25
2g tps $25
weapon r coolant overflow tank $50
the shell minus a few parts $1000
any parts you need just ask. do not be afraid to offer but also dont lowball me
you can msg or text/call 443-226-5018
1g coil pack $45
hks 272 cams $offer
act flywheel $150
transfer case $250
2g maf $50
3 pod a pillar $30
new iac $50
1g tps $25
2g tps $25
