deejay21
- 37
- 0
- Dec 26, 2002
Last week, my 97 GST started running crappy -definitely feels like a misfire. Took it in, and pulled a p0304. The shop I took it to recommended changing the plugs and wires, which I did. The car ran fine for a couple of days, after which it started to have the cylinder misfire! I replaced the 1/4 ignition coil, but that did not help at all. I also noticed that when the engine is cold, it seems to run fine, but the warmer it gets it then starts to misfire. I took it into the shop this morning (drove fine on the way over) and was told that it pulled:
0301 - Cylinder Misfire 1
0201 - Injector 1 Malfunction
0335 - Crank Position Sensor
Shop quoted a price for a diagnostic of $178, but before that I wanted to get the opinion of the community. I know it probably needs the fuel filter replaced, but are there other problems that you guys think this might be indicative of? Also, I have thought about the transistor module as well, but can't find out the part number for 97-99 turbos. Any help would be greatly appreciated - you guys rock!
