2G P0170 Fault, JDM 6 bolt Oxygen Sensor
bobbafet7
Dec 13, 2005
Newburgh, New York
Recently I have been trying to work out some of the bugs since I had the motor swap done. I am not sure exactly what car the engine came out of. I have been getting a code for p0170 for the fuel trim concern.
Now I have an air/fuel ratio gauge in the car and the reading on it have been inconsistent since the swap or it will only read all 1.125v so I assume that I may have gotten a bad upstream 02 sensor with the engine. My concern is that the plug for the sensor does not match what a US spec engine has and I hate to cut and splice a universal sensor in there if I can avoid it.
Does anyone know if there is an oxygen sensor that will plug into the JDM harness. I tried a Talon and a Galant VR4 and neither one worked. The plug was too long on the Talon and too small on the Galant.
Any help would be appreciated.
You might try to lookup an international site for like an old evo o2 sensor replacement and price how much it would be shipped to the us. No idea if that would work at all but you might be able to see a picture of the harness to see if it works or somthing.
