Oversized Main and Rod Bearings
cherrod8
36
Nov 26, 2009
Hampton, Virginia
If my G4CS (6 bolt 2.4) is being bored .020 over where can I get some 6 bolt oversized bearings?
I'm destroking the motor with a 94mm crank and longrods.
Boring the cylinders doesn't affect the size of the bearings, do you mean your crank is being machined?
The crank isnt a stock size and it's going to be in a block that comes normally with a 100mm crank. I was just giving extra info because I know people like to ask all kinds of questions before answering the OP.
I'll just hit up ACL and see what oversized bearing choices they have.
well you need to know what the std main size of the stock crank is, then compaire it to the main size on the 94mm crank.
That will let you know if any cusstom crank work is needed, and what size bearings will be needed.
