overboosting????
ZyklonBZombie
217
Oct 20, 2002
Stamford, Texas
help me ... i don't know if my boost controller is fubared or what but i am running like 25+ psi on the lowest possible setting. when i connect the wg to the turbo elbow i run like 11 to 12 psi. also when i connected everything back to stock i run mad boost again. what could be the problem? :thumbdown :( :mad: :confused:
oh yeah ... a little history. i hooked up the mbc a few months ago and it worked fine ... had it set at 15 psi ... then i hit this dip and ripped my flex piping on my exhaust and it screwed everything up. i put a stock 1g bov back on and it was boosting at 18 psi. the i rerouted the mbc to the turbo elbow instead of the bov line and it was at 20 psi .... soon after i just removed it and plugged it straight from the wg to turbo elbow and it was between 10 to 12 psi. i reconnected the mbc yesterday and it was boosting MAD 25+ psi no matter how i connected it. this morning i just put back to stock and it's basically the same deal.
well nevermind on anything... i am running 15 psi with no boost controller ... i just connected the wastegate to the bov line ( T'ed it) ;)
