Output Shaft Bearing HELP!!
C_LOS
Jan 13, 2007
Myrtle Beach, South Carolina
My motor is at a hault, i cant find anyone that sells the caged output shaft bearing (yes, the crappy one with the plastic housing that breaks) for the 420a motor NV-T350 trans, i pulled my motor because i was having a nasty griding coming from the bell housing, pulled the trans apart and found nothing then pulled my clutch off and the flex plate was broke in the middle (converted to a non modular clutch setup, thanks to bulletdsm's how-to at 2gnt) anyways was putting everything together and the cage broke on the output shaft bearing, luckly i found all the needle bearings but now i cant find that part....i have called mitsubishi and ordered part after part and they can't get it right, ive looked online and nothing, i would love to put a bearing with an upgraded metal cage but if i cant find one then ill just put the crappy design one on..help me out fellow dsmers gotta get my ride back on the road
