Orginal boost on a GST ?
Andri sti
Jul 5, 2008
Reykjavík, Europe
hi this is my first post :thumb:
i just bought an Eclipse GST its a 1995
well i just instaled a new boost gauge and if i let the car pull upp in 3 gear it hits about 8-10 psi .
Is that normal ?
Also wen i rev the car it hits almost 0 rpm after i step on the gas .? is that the intake or should i look at something else?.
The only mods so far is a K&N air intake ....
Edit i put my T for the gauge in the hose that leads from the blow of valve to the throttle body.
Is that normal ?
Yeah, that boost is normal. Be more descriptive on your rpm issue, I'm not sure what you mean. You should not tap the bov line for anything. Move your T to the fuel pressure solenoid line, it's the line coming out of your intake manifold on the front far right(as your looking at it).
Well the RPM problem .... if i rev the car ...but not in gear(Standing stil) ...it almost stalls ven the rev´s are coming down again hitting almost 0 rpm
is your blow off valve open atmosphere or recirculated because i had that problem with a vented one plus the stock blow off valve is a peice. re tap your boost gauge and see if that fixs your problem
yes yes ...im sorry ...but i did not have the time to look at all the posts ...but next time i´ll spend more time using the ''Search''
