2G Ordered a Quaife LSD, Want to Put in a 16G Turbo Now Need Help
Ferp
159
14
Sep 14, 2014
Edmonton, Alaska
Okay so I ordered a Quaife LSD so now I'm going to start looking at putting more power out.
My engine is basically stock. I have a KNN CAF and a 3" exhaust, everything else on the motor is stock. I would like to put a 16G turbo in but I want to get all my supporting mods first.
What should I be looking at?
Walbro 255 fuel pump
What size injectors? 455cc?
Thanks for any help you can give me.
http://www.dsmtuners.com/threads/1g-dsm-upgrade-paths.486218/
http://www.dsmtuners.com/threads/2g-dsm-upgrade-paths.486217/
Right at the top under Resources.
You'll need an AFPR for that 255 pump. A 455cc isn't going to mean crap since stock is 450cc. Unless you're one of the few with a 1g automatic running 390cc.
*edit*
You'll also need a way to tune for the bigger injectors. My advice on what to get first? A way to tune. None of the mods will mean jackall if you can't even get the injectors dialed in right.
Make sure the engine is healthy by catching up on fuel filter, tbelt and any other service stuff.
then get a pump and regulator, ecuflash or dsmlimk, 1150 or smaller injectors,bov, and u should be good. An intercooler would be a great idea. You probably need a clutch soon.
So I just had a full service and had all my cam seals, belts, fuel filters etc. changed about 1K km ago. My clutch is 6,000 KM old so it's fine too.
How much horsepower do you want.
Between 300-330.
Should this be enough to safely/reliably run the car at 300 horsepower at the least?
650cc injectors
DSMLink
Front mount intercooler
Manual Boost Controller
Boost Gauge/Oil Pressure Gauge/Wideband A/F Gauge
Walbro 255lph fuel pump
An AFPR (can anyone recommend me a good affordable one?)
A Greddy Type RS (is there a different one I should get other than this or a 1g?)
16G Turbo w/ install kit
Also about how much am I looking at cost wise (give me a wide estimate) for everything? I can do most of the installs myself but might need to get a few things put in.
  • Wanted 6 bolt NT water pipe
    • chrisman287
