Options on Transfer Case
jayb903
99
4
Jul 19, 2007
Fayetteville, North Carolina
I've recently discovered a huge hole in my xcase:ohdamn: and wanted to go over my options.
A) Send it in to transmission shop to get welded up
B) Buy a 97+ xcase(kind of hard to find used)
I know the transfer cases have a different gear ratio in the 97+ models.
So far these are the only two options I can think of.
Thoughts?
If the cases are the same you can just buy a t-case from another year and put your gears into it. You can probably order a new section of the case from the stealership too. Repair might be the cheapest route though. Where'd you get a hole at?
On the top where it is closet to the block/pan. I was unaware of being able to switch gears out of it.
Thanks
yes I'm sure. Transfer was punched when rod let go.
