only 9lbs of boost
shawny2087
75
Apr 15, 2005
milwaukee, Wisconsin
i just got my new VDO gauge installed in my vent and im only pushin 9lbs of boost so i checked for leaks and i have none but if i put the hoses on the BCS wrong can that be a problem or does it not matter?
Agreed. Post up how you hooked up your BCS and we'll try to correct you. The BCS is the factory form of a boost controller. It can reduce your boost pressure if it picks up too much knock.
