Once again my dsm has failed me
soulweaver
181
Dec 1, 2008
Pevely, Missouri
I was trying to figure out why my dsm was over heating and found out that it is probably air in my coolant lines or it has a blown head gasket. Then one night I parked it out side of my house and went inside and went to bed. The next morning I come out to start it to go to work and the damn car wouldn't start. So I check the spark, compression, and fuel (I checked to see if the fuel rail was getting fuel) and they all worked. But I did notice that my spark plugs are getting soaked with fuel. So I poured some rubbing alcohol down my spark plug holes and then let that sit over nite and put the plugs back in and tried starting it and nothing happened. Does any one have any idea what my problem can be?
I also need to know what color wire goes were on the harness for the Engine coolant temperature switch (air conditioner). It goes in the thermostat and it's the top sensor.
Does anyone have a pic of the coolant temp sensor wires for a 1g. Thats what I need for my next test for my car.
Were my links to the VFAQ site not helpful to you? You have NO CELs whatsoever? Fuel, spark, and all sensors are working? If you have the right plug wires are attached to the right plugs and coils then you should be good to start. :confused:
