Old 5 Knob AFC
~laser_craver~
470
Jan 16, 2003
Montesano, Washington
I need a manual or link that will show/ tell me whats what as far as the settings and selections on the back of it. As in car type, etc. There's a bunch of different options but iono which is what.
Looking at back should be:
down,down,up,up,up,down,up,down
car select should be ZERO
wires should go:
Red wire = power
Black wire = ground
Green wire = rpm signal, pin # 21 on 1G.
Yellow wire = Airflow sensor, pin #10 on 1G.
White wire = Airflow sensor, pin #10 on 1G.
Cut airflow wire. Yellow wire toward ECU. White wire to harness going into car.
What do i open a pdf with? I tried it in notepad and word and it just gives a bunch of weird symbols and stuff. BTW this afc is being put in a 92 with a 90 engine and harness if that makes a difference. I pulled it out of a 90 awd. Ill write up the settings its on currently.
down, down, up, up, up, down, up, down car select is on 1
When i pulled the harness outta this 90 i left the wiring for the afc wired in and it has 2 harness's for the afc one with the plug into the backa dn the other has the black and white wires with plugs on the end of them similar/same as the plugs you would use to attach speaker wires to speakers and the green and red wires go to a lil red led light. I dont have any clue as to what in the heck this are being used for i will get in there and see which wires are attached to what as far as ecu pin #'s and harness wires.
Ok got the manual got it all figured out he has it wired right. He also has a power supply from the o2 sensor and an extra ground. My guess on those would be non other than an A/F Gauge. Then he has a power supply wire and a ground wire ran to a lil red led light. The power side coming from, what looks to be from what the ecu pinout on vfaq, the wastegate solenoid valve. So what the heck? Is the light suppose to come on during full boost or something? I'm lost as to why this is even here and what it does.... :confused: Anyone?
