Okay to take off Overdrive
urbanvibe
Dec 19, 2004
Red Deer,
Is it okay to take off overdrive when im passing someone? I really need the higher rpms power as opposed to the weaker 4th gear.
So say im already in fourth, can I take off OD and switch back to third without hurting anything?
thanks
Depending on how I'm passing etc I'll do it so that I can ease in and out of D instead of nailing the gas and slamming into it.
I did this on my stock trans for a year...then an end clutch/shift kit trans for a year....and now with an IPT trans for six months....no problems. My trans failed in August/September from a clogged cooler :rolleyes: so if that didn't happen you can bet I'd still be on the stock trans..
  • Wanted 6 bolt NT water pipe
    • chrisman287
