ok MBC question
Talon5786
78
Jul 30, 2003
abingdon, Maryland
Ok guys i got a MBC of my buddy and i have it hooked up my boost spikes at like 15-16 but then drops and hold at 10-11 is there anyway i can get it to hold at 15. My car is stock minus the 2.5in exhaust from the manifold back and the hacked air box with a kn&n air filter any feed back would be great thanks:talon:
Be sure you have the boost controller hooked up properly and with good lines. IE: from compressor outlet to MBC to wastegate actuator. Keep the lines short.
A boost leak test is probably a good thing to do.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
