ok i have this code
Status
Not open for further replies.
GSX77901
59
Jul 31, 2004
Corpus Christi, Texas
I got this code P0412 its says-"malfunction exisis in the electrical circuit for switching valve "A" of the secondary air injections system. Were can i find this on my 95 Rs??
Gah. That secondary air injection system seems like such a worthless idea. Makes you wonder (aside from knowing its intended purpose) why they bothered...
what the recall and one of the links don't work and how dis this effect my car cause my car is running like crap and i think i have a 02 out
I'm sorry, but what the hell did you just try to say? Gimme a break, man. A little effort goes a long way around here.
If you have a code for the secondary air system then you AT LEAST have a problem with the computer seeing this component when it's NOT really there OR... this component is there and is malfunctioning.
Always fix what you KNOW is wrong and then go from there. We have seen bad o2's on a regular basis but you did not list an O2 code and the only intellegent conclusion to come from based on the limited information you gave would ONLY indicate that you DON'T have an o2 code.
Please take a little more time to proof-read your posts so that the people trying to help you... can understand you first.
Thanks,
Doug
The codes i have are P0402 and P0412 and P0135. I was asking how the secondary air injection system effects my car. My car is runing like crap and disnt seem to idel right. When i start the car it seem to try and turn off and idels rough. When the car is warm it turn on right away but still idels like crap.
When the secondary air injection system isn't functioning properly, your car will be runing like crap and disnt seem to idel right. When you start the car it seem to try and turn off and idels rough. When the car is warm it turn on right away but still idels like crap.
It's told you what to fix. When you're done, get back to the ESL classes. And next time, use the Spell Check.
Status
