Ok ao now i am the proud owner of a 1997 GS-T
jrdrew5
508
Oct 14, 2009
jacksonville, Florida
But i have so issues the car sat for 6 months before i bought it cause the past owner blew the transmission and let it sit till he put it on craigslist,
So i met up with the guy 20 year old, he had a friend who had a brand new transmission he wanted 300 for and 300 for install i said ok so they went on with it, after car was done started first time test drove fine, then on my way home which was on 30 miles clutch hit the floor and would not go in gear and the clutch would not come back up, so broke down spilling clutch fluid everyone i had it hooked to a rope and towed home, guy said he would be there in the morning, which he was (SUPRISED) good guy tho. so when i was pushing it to the slab to work on it, clutch was back up and gears worked fine, started up right away backed it up to the slab jacked it up bleed the clutch put fluid in it changed the oil seems fine again, but my pedal is real low to the floor i mean alll the way LOL,
and im still leaking oil and some clear none slick fluid that seams not to be water but not clutch fluid, and my blow by makes ppl not wanna ride behind me LOL,
Anyone have any insight at this?
No but it will make your car run better in general. By not recirculating your ECU is getting incorrect measurments
