oil seal leak
talontsi2333
Jan 3, 2004
noblesville, Indiana
i know my owl seal is leaking, i have a puller but i can't seem to get the crankcase off to get to the oil seal can anyone help me out on this problem?
Its a tight spot so not a lot of options.....
1.Try touching it let the metal expand and try pull it off.
2. maybe its you tools... if you using a "el cheapO" puller maybe you should get one with a little more meat to it use that.
A.rememeber you also have to elivate the timing belt tension(if you have not done already
good luck......
