oil pump sprocket won't turn
sr22tsi
41
Dec 15, 2004
mooresville, North Carolina
ok...so my balance shaft belt snapped and took the timing belt with it. bent two valves, but i got everything fixed and ready to put back togather. i was lining up all the sprockets but when i tried to line up my oil pump sprocket , it wouldn't turn. everything else is turning fine. i have no idea what the problem could be. ppplleeaaseee help :cry:
Same thing had happened to my car when I had purchased. The oil pump shaft was tweaked from the balance shaft belt going. Long story short I went through two oil pump sprockets before realizing this and having to buy a brand new front cover. Good Luck
so how did you fix it?
just ordered a new front case and the bsek from jackson auto machine. should fix the problem. and i won't have to worry bout any more snapped balance shaft belts. :D
