1G Oil pump MD129347 the same if you buy from Chrysler?
BoostedBeaver
Moderator
957
289
Aug 15, 2009
Augusta, Georgia
I know this is the part number for a assembled case with the driven and drive gears, but I gave this number to a chrystler dealer and it was significantly less. It is the same part number and is called a front case assembley. Is this the same part???? Thanks in advance. :confused:
I should have made the title different, but I can not change it now. I know the front case comes as three pieces. The case, driven gear, and drive gear are all seperate parts. This MD129347 is for a assembled case meaning it is suppose to include all three. If you type the number in any mitsu place it will say CONDITIONAL INTERCHANGE meaning you have to have other parts to go with it hence the drive and driven gear. My question is will the MD129347 still be the same if it comes from Chrystler??? When you give a Chrysler place the number they can pull it up. It should be the same, I was just looking for some verification.
The pump must be ordered in three pieces now. The above part # is no longer available. Mits parts was the cheapest place I found by the way.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
