oil pump exam problem... with pics.
n8dsmdriven
125
3
Aug 23, 2009
Oregon
oil pump question..
ive searched all over but cant seam to find what im looking for...
im doin a bs shaft delete , while considering replacing my oil pump? here s the question...
on the oil pump, what ARE THE OEM MARKINGS . AND WHAT ARE THE TOP LINE MARKING AND SUCH....
i have a spare pump that i came across it my garage of a used 6 bolt.
QUESTION is..... is this a oem pump or aftermarket garbage???
thank you
At least the pump looks like its topline, I just put the same in my rebuild, looks the same from the casting qualities of it. Says right there JIC is the mfg.
The inside parts where the oil comes in contact look pretty clean, did you clean the case at all? Maby it was already replaced?
  • Wanted 6 bolt NT water pipe
    • chrisman287
