Oil Pressure Value at 800+/-50 RPM idle
xteekayx
55
Feb 19, 2005
North Jersey, New Jersey
Guys i've searched and can't find what the oil pressure should be at warm idle on a ca with 6bolt motor. I've searched and got some idiotic arguments of conversion from bar to psi :-\.....
So i just want to ask what is a typical value (in PSI) and what value does the manual say that should be at warm idle at 800+/-50 RPM?... there reason i ask is becasue i have autometer oil pressure gauge and it reads preatty low...
at idle your oil pressure is always gonna look low when the car is warm but once you hit the gas it brings it right up. i believe at operating temperature i believe it should read like 30psi and about 65psi at 3000rpm.
The factory service manual calls for 11.4 psi at a warm idle. It seems low, but as long as it rises to 30+ when your cruising, your good.
