Oil Pressure Gauge Help
95AWDGSX
32
Feb 9, 2004
West Orange, New Jersey
I drive a 95 Eclipse GSX. Can anyone tell me how to fix the oil pressure gauge? There is definitely oil in the motor but the gauge doesn't function at all. Thanks.
I'm not completely positive that it is the same on a 2g, but I would imagine so. Get down by your front left tire and look into the engine bay. You should see a wire going from the oil filter housing back to a metal piece that is kinda shaped like a can with a little rod coming out of it. Make sure that this wire is connected to the rod and it is not loose.
YA WHAT HE SAID ^^^^^ .. all tho- stock 2g sensors dont tend to have there connectors fall off as easly .. is does happen alot to 1g's.
  • Wanted 6 bolt NT water pipe
    • chrisman287
