Oil on the spark plugs
OBie20
Aug 11, 2005
Boston, Massachusetts
I went to change my plugs today and when I pulled out the plugs there were covered in oil...there was oil on top of the valve cover that has been there for a while... no smoke coming out of the exhaust so I dont think it is the head gasket..what should I do? How do you get the oil out of the valley...the car runs great though...thanks
There are four circular valvecover gaskets that seal the sparkplug holes. One or more is likely bad. Oil on top of the valvecover means either you have a crack in the VC (overtightening the bolts) or your oil cap gasket is bad :dsm:
Replace the seals, or buy another valve cover. If you DO buy another one that has been powder coated (Bonehead Performance) make sure you get all the sand out.
Was the oil at the top of the plug or the bottom? You need to run a compression test and make sure that you're not having excessive blow by (alot of oil getting through your piston rings).
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
