Oil level indicator
1AWD90
134
Sep 6, 2007
Marshall, Minnesota
Can anyone tell me why when I check my oil it shows full. However, when I turn my dipstick 180 deg., reinstert it and check it again it shows that its almost a quart low. :confused: oh its a 4g63t awd
unless you are checking from a cold start it would be accurate if you have been driving for a while and checked. If you have been driving for a while and pop your hood to check, I would pull the dip stick and wipe first. Then, pull it back out and that should be an accurate reading.
So you are saying when you put it back in at 180 degrees it shows that you are a full capacity and when you do another 180 it shows you are a quart under??
Yeah thats exactly what im saying. I have tried it multiple times because I could never figure out how right after I do an oil change im a quart low then all sudden im right on then check it again and im a quart low. Its crazy and its driving me nuts because I cant figure out how this can be.
