redeclipse7782
- 463
- 7
- Oct 20, 2004
Worcester,
Massachusetts
I have some sort of fluid leak on the ledge of the firewall on the backside of the motor. I cant tell what it is. It completely covers the ledge when i drive the car but when I'm not driving the car i cant see anything dripping or spraying. Checked motor oil, power steering fluid, brake fluid, clutch fluid, and even coolant for the hell of it. All of these fluids are at there normal levels. I am assuming it is transmission fluid that is somehow leaking onto there. Could it possibly be spraying out of a drive axle and onto the ledge? Which would also explain why I dont see anything when the car is idling because the transmission is not in gear. Are there any area's I can check on the transmission for common leaks?
