Oil jet crush washer
gettingwop
72
Feb 15, 2008
dallas, Pennsylvania
I have spent the past week between A&A auto (Keystone), NAPA, Advanced Auto, Autozone, Lowes, Home Depot, a local Ace hardware, and two other very local hardware stores, and a local dealership. I am unable to locate the crush washers to replace mine on the oil jets. I haven't had any luck with locating anything except Advanced had some 'help' brake line washers which we're like 11mm. I grabbed all of them they had. I'm not sure if I'll be drilling these the mm yet. Option two was after an hour standing at the parts desk at the dealership I can order the washers for like 3 a piece plus a week shipping. Option three is a guy on e-bay has these for under 2 a piece, with a...ready for this...5 dollar shipping fee PER DAMN WASHER! The seller will not give a discount on shipping, even though all 8 would fit in the same envelope. I heard I could get them at slowboyracing.com however I had no luck locating the washers. I have the part number off hand I believe it was mf660034 63 or 64.
Sorry for my ranting I'm just tired of searching.
Does anyone know the manufacturer of the washers we use or could use, or you have used?
Where did you get them?
Off topic but I am using 80mm long bolts to hold my engine to the engine stand, they wouldn't fit through the holes so I had to reverse the mounts and get washers to fit the engine to my stand. Again running into issues with finding something that should be simple.
Where can I locate 10x1.25 bolts in like 100mm? E
ven better does anyone know where I can get 10x1.25 rods?
I haven't seen a metric rod anywhere, and nowhere carries anything over 80mm bolts.
Thank you in advance.
I usually reuse the crush washers... anytime I've had to replace them due to losing them I usually go to True Value hardware. I've never ran into a problem reusing them however. As for your engine stand bolts, I just take the bolts from the turbo and use them to mount the engine - they fit perfectly on my cheap stand with length to spare.
