Oil in intercooler
drewbuddy
113
6
Jun 19, 2011
edmonton, AB, Canada
When I took my laser apart I found between 1-2 cups of oil in my intercooler and not sure why. I haven't found anything on the forums yet. My turbo has a little vertical play in it, fins don't rub as far as i can tell. When i took my pistons out my #3 had separated from it self. Maybe that is why. I don't know why it did that. Any advice on this, or anything else to do with my rebuild would be greatly appreciated. Thanks
I would say one of 2 things, the turbo oil seals are bad so it pushing oil in to the pipes, but you would also have blue smoke coming from the exhaust when boosting, or it could be a build up from the vent from the valve cover that goes in to the intake.
This is my first car with a turbo, so I don't know anything about rebuilding one. I see there is some stuff on here showing how to do it. I will try to check him out. Thanks talon2gbuyer
