Oil Feedline Problems and Options
Boost95
403
Oct 21, 2004
Wilkes Barre, Pennsylvania
I finally got around to puttin in my new Big 16g. After installing everything and finally starting it up I was leaking some oil from the feedline into the turbo. I figured it was because I used the stock washers, so I replaced them. When re-installing the feedline from head-turbo i somewhat stripped out the feed at the head. Now it is leaking at the head and STILL at the turbo even with the new washers. I don't have a torque wrench, so I don't know exactly how tight the turbo's banjo bolt is. I think it is suppose to be about 25 ft. lbs. I don't want to overtighen it and strip it out also. That is my problem.. Now for my options.
I am thinking, going with the relocation to the filter housing would be my best option. My questions are what i should do about the semi-stripped head feed fitting. Once I have the correct bolt to block it off what should I do? Do I need to re thread it even to block it off, or I had a thought of using some JB weld WTF I'm just hoping to get some replys from people who have had a similar problem and what they did. Thanks in advance! :thumb:
-Mike :dsm: :talon: :laser:
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
