Oil Change Amount
nastynas
69
May 19, 2004
Thunder Bay,
The specificationspage of my manual is missing, i was wondering how much oil I must add. I bought a jug of Mobil 1 synthetic, i think it was 4 quarts if i remember right, and i added the whole thing. the dip stick is useless because it scrapes on the pull out. does anyone know the required oil amount?? :talon: 1990 Talon TSI AWD
DevilSperm said:
good point, i have the ghetto water cooler
Despite how much Buck is (justifiably) frightened of them, the oil-to-water oil cooler really is a better concept until a gorilla either crushes it or uses a filter that won't keep its seal. Having the oil cooled by the water, or the water heated by the oil will give a more stable oil (and overall engine) temperature than running the oil out to whatever temp the cooling air happens to be at a given time. Having the cool oil on a just-started motor warmed by the much-more-quickly heated water jacket coolant is a good idea.
Of course, having the water and oil too-easily mixed is bad, as are more leak liabilities. But it still isn't really "ghetto".
Usually jugs of oil are sold in 5-quart capacity, which most V-8s use.
And that's gotta be a helluva scrape to make the dipstick unreadable.
