dwdsm
- 595
- 45
- Apr 28, 2005
Scenery Hill,
Pennsylvania
So I was considering to squeak a little more power out of the 6bolt. I was interested in taking the redline somewhere between 8-8,500k. I have the old comp 101200 cam with an all stock head. Turbo is a pte 3051 so it should like the extra 1,000 rpm to boost. My question is do the stock valves take the added pressure on the stem? Anyone have the oem valves pull apart? I'm worried about the added 75lbs of pressure on the tips.
Oem specs.
Closed position
pressure & Length (intalled specs)
[email protected] Valve closed
Open position
Pressure & length Valve Open
[email protected]
BC valve spring specs.
Spring Pressure: BC1100 Seat: 1.550" @ 84 lbs
Open: 1.000" @ 235 lbs
Coil Bind: 0.935"
Oem specs.
Closed position
Open position
[email protected]
Coil Bind: 0.935"
