OEM boost gauge?
Ummm....not really. It is an electronic gauge that sorta guesses airflow based on things like Throttle position and other parameters that the ECU sees, then it sorta comes up with a number and sends that to the gauge.
I sheared off the turbine wheel of my T3, and the stock gauge still said I could still boost :confused: so no, not accurate at all in my opinion.
Haha thats great! Do you guys know what PSI i would be running in a stock 1g auto? Is it around the 10 PSI the gauge shows me, being a stock car?
Whatever your actuator spring pressure is on your car. If you are showing 10psi on a boost gauge and don't have a boost controller to turn it up, then the spring pressure is 10 psi.
