??o2??
4g63swap
258
Aug 9, 2003
I just wondering if you have to have the o2 sensor in the exhaust or can that be removed? I have a 3" downpipe with cat removal and don't what to drill and tap a hole. other question can I use that same o2 sensor for the one after the turbo or are they diferent. with out the second o2 sensor will that cause any problems?
thanks
4g63swap
you should prolly throw a check engine light if you don't have it plugged in right. Even if you do plug it in you most likely will get the light though since you don't have a cat. Just drill and tap the hole ... what's the big deal?
