O2 Voltage Reading
HPfreak
44
Jan 24, 2006
Jackson, New Jersey
Hey guys i have a 95 eclipse 420a turbo and i hooked up a safc according to the instructions on 2gnt.com with the blue wire mod and when i try to monitor the o2 voltage its reads aroung 1.5v. If i adjust the fuel curve in low throttle it does change. My question is why is it so high because on 2gnt.com's how to tune the safc says that it should be at 0.92v. I got the 1.5v reading with bothe the old o2 and a brand new bosch direct replacement o2. Thanks guys any help will be appreciated.
You should run 0 to 1 volt. Depending on the condition. Does the voltage fluctuate? If not, you have some other problem, maybe you hooked up the wrong wire. Do you have an air/fuel meter? If you are getting 1.5 volts at wide open throttle it is going pig rich.
I guess there was something wrong with the afc beause i disconnected the blue wire from the o2 signal wire and the afc still reads 1.5v and it fluctuates about +- .04 v
sorry but i used a volt meter to check the voltage ... i guess i should have done that from the beginning thanks for you help
  • For sale 4G63 ARP 7 Bolt Head Studs
    ARP 7 Bolt Head Studs $65 + shipping & paypal fees* torqued onceYou must be registered to...
  • For sale 1g 1G OEM Knock Sensor ( great condition )
    1G OEM Knock Sensor $85 + shipping & paypal fees* sensor is in great conditionYou must be...
  • For sale 4G63 NEW ARP 4G63 Main Studs
    NEW ARP 4G63 Main Studs $50 + shipping & paypal fees* these are $81 onlineYou must be...
  • For sale 4G63 NEW Ferrea Competition Plus Intake Valves
    NEW Ferrea Competition Plus Intake Valves $140 + shipping & paypal fees* these are 8 Intake...
  • For sale 2g S90 Throttle Body
    - S90 Throttle Body, brand new. Purchased this month from STM. Comes with the FIAV block off...
    • Bedicine
