burkgonzo
- 1,007
- 16
- Oct 27, 2005
Wichita Falls,
Texas
If you are running ECM link, you should have one of these Nitrous systems on your car.
http://www.nitrousexpress.com/product-details.php?id=1499
http://www.nitrousexpress.com/product-details.php?id=1539
I spoke with the guys at NX and here's what they said... Both of these systems are a quick and easy way to add big power and eliminate turbo lag. These nitrous systems are designed to be used with an ECM link engine management system. Since ECM link can add fuel through your engines existing injectors, you do not need to add nitrous enrichment fuel through the nitrous nozzle (like a normal wet system). Since its spraying nitrous only, you can inject the nitrous really far forward in the airstream. This will maximize the cooling effect to your air charge for greater power while using less nitrous (they like to install the dry nozzle close to the outlet of the intercooler). You do not have to tap into the fuel system, installation is very quick and simple. Since ECM link automatically includes full throttle activation functions, rpm window switch protection and many other cool protection features, you do not have to buy a bunch of expensive accessories. These systems includes nitrous jets for 35-50-75-100-125 &150 HP (optional jetting is available for 12HP – 250 HP). These dry nitrous systems come complete with a single dry nozzle, nitrous solenoid, 10lb bottle, stainless bottle brackets, stainless braided lines and more.
