NT pstions on a t3/t4
4g63telantra
454
Dec 10, 2004
Toronto,
A few weeks ago, i posted a question on "whats the best compression ratio to use when running a t3/t4?"
I got a few replys on people saying to use 9.0:1 compression ratio or something on the higher end so that the turbo can spool up quicker.
So now that i know the NT motor is 9.0:1, just wanted to know can i use the pistons off a NT 4g63?
NT pistons weren't made to handle boost.
If your going t3t4, get at least 95 pistons on 1g rods. Or, you can opt for forged internals. Compression wise for a street car, I would say 9.0 at the max. I would feel safer at 8.5.
I am using 9.0:1 JE Pistons with my TO4E 60-1/.63stg3 set at 30 psi of boost and works excellent... same turbo/same boost was on one of my friend's GVR4 but with 7.8:1 (or less) and it spool-up at 4000 to 4200 RPMs exactly like mine.
So it will be the same for spool-up, but the truth is that less comp ratio will handle MORE BOOST and MORE TIMMING getting more HP. Think about…
Nxt time I'll go less comp ratio.
:thumb:
mig
you forgot to mention thats only on pump gas. on race gas the higher compression motor will run away on the dyno and on the street. i am in agreement with 9to1 is perfect compression.
:thumb:
mig
Nxt time I'll go less comp ratio for a daily street setup. (using pump gas - thanks peregrine) :shhh: :rolleyes:
on a daily street setup ill go with a completely stock car. that way i dont have to worry about it breaking down. or maybe ill take the bus like the rest of the sheep :rolleyes:
