not sure whats wrong
turb0talon92
Jul 16, 2005
Newburgh, New York
I have a 92 AWD 5-speed , when i bought the car i noticed it had a little vibration when i start hitting the gas.... then it would eventually even out as i sped up....it kind of feels like I'm going to slow in a gear but I'm not....its not the balancing of the tires .....i checked the transfercase fluid,transmission fluid, an rear fluid, all full,well the vibrating is getting worse now , any info would be greatly appreciated.... Ty.......Joe :talon:, ty for your replys...it happens at lower speeds, when i'm on the highway its fine,it is on acceleration not wheel speed....ty :talon:
Is it high speed vibration? If it's a wheel speed type of vibration and only on acceleration it's possibly a bad inner cv joint. Let us know if it's engine speed or wheel speed. Good Luck
I agree with Mitsu Tech. Tell us if its wheel speed vibration or engine speed vibration.
I had a similiar problem that turned out to be inner driver side CV joint.
Also had a problem once that involved not "torquing" the driver side front wheel.
Check your lug nuts.
gsxtacy
