Normal spark plug? *large pic*
scaryc
54
Sep 6, 2004
warren, Ohio
my plugs are only about two months old, i pulled them out to check the gaps and every one looks like this. can someone tell me if this is anything to worry about? maybe lean mixture? ngk plugs
1993eclipseGS said:
Well, If your sparkplugs turned into a little white box with a red x in the middle, That is definatly something to worry about :confused:
it works for me . .. can anyone see the picture??
Those white dots on there that actually make the tip white, well that is aluminum dust from your piston. I would definetly say you need to retard the timing.
But yours is a N/A so i dont know, but it does not look clean.
when i changed my plugs a few months ago, there was a slight white coloration on them, it seems it's gotten progressively worse
Wheels-a-turnin said:
I'll be honest i dont know but could quite possibly be. Have you done any tuning yourself or anyone else recently??
the car is all stock, i put a k&n filter in it and some airbox modifications like removing the silencer, but other than that, nope
thanks for all your help guys, every reply is greatly appreciated
all of them look like that?? you are running lean...can you set the base timing on your n/a? lower the timing.
i doubt it's an intake leak, but ill check. i'm definitely going to reset my timing. about the oil on the threads, the walls of the spark plug holes are extremely clean, i cant see oil getting in through those rubber seals. i must be burning it :(
