non turbo trans to turbo trans swap
Duke901
111
Nov 29, 2005
Sylvania, Ohio
What parts will i need to swap a fwd turbo 5 speed trans inplace of my non turbo trans, i know i will need a turbo flywheel, clutch and pressure plate, but anything else.
Thanks Mike
The axles from the 93-94 trannies are bigger than the previous years so if you get one of these your gonna have to grab new axles (all the hubs are the same). Also, the bell housing on the turbo trannies are bigger which makes it rub slightly on the big cross member. A solution to this would be getting your hands on turbo fwd motor mounts or notching out the x-member (which I think would work).
