no2 on stock internals
What are your current mods?
And as far as going spray on the stock pistons....um you may not like to hear it but I would definitely swap your pistons/rods with"SOHC Neon"pistons/rods. that would lower your compression,
9.6:1 with stock DOHC pistons/DOHC head
vs
9.0:1 with SOHC pistons/DOHC head
witch would also give 420A's the ability to run higher boost levels with a budget.
I don't know about 9.0:1, but with the SOHC piston you should be around something like 9.2:1 - 9.3:1 depending on how many thousandths your head is decked from stock. I know with the SOHC neon guys it's a bit of a benefit for the DOHC pistons witch take them to 10.2:1 - 10.3:1 compression over stock (9.8:1) for N/A applications. Regardless of the compression ratio, your still limited to 300chp (depending on what shape your engine is in / fuel management used), making forged pistons/rods the best way to go for force induction. However; the SOHC pistons will allow you to have more room for error; tuning wise witch is good, especially if one is running the stock PCM.
Just my .02
For me I would not do any serious mods such as nitrous or a turbo on a stock 420a. They really can't support that much power. You would be better off to save up and build the motor from the ground up. You will gain some hp but you will not have to worry about anything breakin if you do decide to turbo or add nitrous. just my 2 cents.. I have a 95 GS and a 95 GS-T. I know to build the motor first or take car of it. My GS is at 202,000 +/- miles and NO Problems. If you take care of what you have it will always be there for you.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
