talontsiboy24
- 868
- 3
- Mar 28, 2009
60457,
Illinois
My bov use to go woosh and never flutter before i installed a new intake pipe cause my old shitty 1g rubber one was torn up....anyways since i put the new intake pipe and put a new longer bov hose on since the old one wouldnt reach with the new pipe when i let off the gas at wot i hear a fluttering sound when before i heard a woooosh sound like how it always been?
i noticed my vacuum line from my mbc going to the wastegate has a bend in it right where it has to plug up to the wastegate because the new intake pipe is over it squeezing it down a lil maybe its causing blockage?
also the bov hose im using is a flex hose with a spring inside of it that i got from autozone since i couldnt find anything else but its a bit longer then my stock one so im thinkin it could be the hose?
before the hose for my bov would come around from the left side to the intake pipe but now with the new pipe i had to bring it around from the right side but does it matter?
, not like you can just leave it.
