No power on a 1g awd?
Effex Unlimited
Jul 25, 2003
I pulled out this morning easy and my car threw a check engine light and almost seems like it is missing, but i am not sure. The AFR gauge is showing a lean condition. Anyone have any idea as to what it could be?
Originally posted by Effex Unlimited
not exactly sure how to check the code output on the 1g's.... if someone could tell me how to then i could.
Try to find somebody in your local area that has a datalogger, or you could even try an autoparts store. Sometimes you can rent a scanner, or if you know somebody at a dealership they might let you use thier tool for free.
By the drivers side door there is a plug that you can short to ground with an led/resistor. This will allow you to read the code numbers. I can't remember how do do it exactly but I know you can check vfaq for it.
If you are throwing a code and showing lean it is probably not firing on a cylinder or not getting fuel. Pull your plugs and let us know what they lkook like.
middle 2 cylinders were not getting spark so i replaced the coils, the igniter or what ever the hell the control box is called under, and the sensor on the intake cam shaft. still the problem persists.???? anyone have any other suggestions?
