no compression in cylinder, poor results across board
Jasper16g
135
May 16, 2003
Morgantown, West Virginia
Hey all,
On my second pass at the track, the car totally broke up about 50' from the finish. Was hoping that it was a fouled plug but apparently not. Here are the findings:
Cylinder 4 (going right to left) - 0 compression, elctrode totally gone on plug, ceramic totally gone as well. Very oily and black.
Cylinder 3 - 120 compression, plug looked ok
Cylinder 2 - 80 compression, ceramic busted and plug looked bad.
Cylinder 1 - 90 compression, plug look ok.
I am guessing a burnt valve in cyl 4 and a possible blown headgasket. Hopefully the bottom end survived the carnage... Going to pull head and inspect/repair. Any other suggestion, thoughts on things to check out or possibly be wrong?
Thanks
SQ
Is this a 1g or 2g?
and what did you run? LOL just want to know.
I did the same thing and the piston was melted down.
Is this a 1g or 2g?
2g
small 16g
FMIC
TBE
MAFT w/ gm 3"
550 inj
A/T
15.4 @ 91 on first pass (terrible 60')
15.1 @ 78 with the "breaking at end"
SQ
Yeah your not going to find out whats wrong until you get that head off. Hope its rebuildable.
Got the head off tonight, burnt valve as I suspected. Bottom end looks to be ok. Now the question is should I rebuild the 2g head, or put a 1g head/intake mani on it? I don't really want to go all out or anything, but just get it back on the road and maybe some performance if possible.
Thoughts?
SQ
