2G No brakes.. Omg..
DsmDanielson
104
Jul 13, 2016
Peoria, Arizona
I read article after article and tried everything and I can't get brake pressure. I just changed my brake pads and rotors. I even painted my calipers to make it all look nice. Reinstalled everything. Bled everything I don't know how many times. Booster works, changed master cylinder (needed to be changed anyway) no leaking brake fluid anywhere. STILL NO BRAKES?!? I don't have abs and I've been bleeding with the car on and off to no avail. I'm officially stumped.. and my head hurts. I've been at this this for 4 days now. Please help me​
Did you bleed the master properly? How does the peddle feel, soft-hard? Was the old master leaking at all? Could have leaked into the booster. My gvr4 did that and had horrible brakes.
This happened to me when I swapped the front brakes to rebuilt 2 piston calipers. Bled them for days and nothing. What worked for me is unmounting the calipers from the rotor and slowly press the brakes to ensure the caliper is pressing the pads. Just a thought.
You cannot bench bleed our masters as we have open systems! That means that when you press it it closes but as soon as you release it the system now opens and fluid can leak out!
What you do is take the 2 lines going to the prop valve from the master and loop them back into the res bottle and press the brake till you circle fluid around and no air is in the master then you need to lock the brake pedal down!!! So you need another person so keep it pressed down while you reconnect the lines back to the prop valve once that's done you can release the brake pedal and bleed like normal!
Resolved: I checked the calipers after looking at what boostdawd said and realized I put my calipers upside down, so bleeding would've been impossible. I feel silly cause I was in a rush but now brakes work. Thanks!!
