no boost need help
nvr2fast
Mar 25, 2006
gaithersburg, Maryland
hey guys need a little help i send my pt61 turbo to precision for rebuild in the process of turbo rebuild i went ahead and added a tial 41m. wastegate on the o2 housing. cut the flapper .got the turbo back and i am not boostin. change spring in wastegate did boost leak test ran air with compressor before boost controller and wastegate open up but with turbo it doesn't. wtf@*** i dont get it. maybe they didn't do a good job a pt
well, i check the wastegate by pressure on one of the fittings .the hose that goes to that comes from turbo side in between that goes boost controller. also i did it while car was on . i been hearing pt sucks lately. i think i am going to send it back unless some tells me what else i should check...
Try unhooking your boost controller. Hook vacuum to the lower port and plug the top one, That should make you run spring pressure... And I don't think your problem is with the wastegate opening, it is with it staying closed.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
