Yamahaulin
- 695
- 12
- Jan 30, 2010
Bowling Green,
Kentucky
If you were going to spray a 50 shot of dry nitrous would you spray it right before the intercooler or right before the throttle body?
But how would you spray it befor the maf. The maf is befor the turbo and it would have a long ways to go befor it reached the intake manifold.
Im sorry if i change the subject a little but i had a 3g eclipse and i asked someone if i could add a 35 shot and they said the maf wont read the nos. It will just confuse the ecu. If you do add nos to a dsm how would you go about tunning to add that extra fuel?
Spray after the IC, but with enough space for the nitrous to distribute itself as evenly as it can.
I've always thought it was best to drill and tap each intake manifold runner for nitrous? Is this not correct?
its not called a "dry shot" or a "wet shot"
its called dry or wet manifold, reffering to where the enrichment fuel is distributed in relation to the n2o..either at the "carb" or the "injector"
for u simpletons out there.
and its not nitrous. its nitrous oxide. is there a difference? ill let you decide.
nitrous is like a hot girl with std's....you always want to hit it but your afraid of the consequences
i like that and yeah it is very true. but back to the topic. if you spray it befor the intercooler, wouldnt it cool it off more and stay cool after spraying it to get a more dense charge afterwards?
