Nitrous Gauge?
gringoloco
56
Jun 30, 2003
Im planning on buying a NX N-tercooler Kit and im wondering what else im going to need? Its a complete kit from prostreetonline.com and comes with all the needed basics, im going with the 15lb bottle setup. But I was wondering if I should get a nitrous gauge along with it (and does the gauge monitor how much No2 you have left), I thought about a bottle warmer also, what else am i missing? Im wanting to go with this setup for nitrous because I dont want to spray directly into the engine. I have all the supporting mods for a good shot of nitrous but im not comfortable running it directly into the engine.
My mods include:
PTE 50 trim, 3-angle valve job on head, arias forged piston(8:5:1), cromoly rings, eagle rods, fluidyne radiator, greddy type-s blow off valve, race short block, dual friction feramic clutch, custom 3'' turbo back w/ n1 muffler, ported Evo 3 manifold, ported 2g o2 housing (going to ported Evo3 02 housing), 255 lph fuel pump w/ adj fuel pressure reg, 550 injectors (going to 680's), 8.5 mm magnecor wires, ngk bpr7es plugs, 2.5 i/c piping, 24" x 10" x 3" custom intercooler (Lang's setup), Lang's TB elbow, 3" dejon tool intake pipe, k & n air filter w/ hacked air can, FAL slimline dual fan setup, 2 step halman boost controller, short throw shifter mod (HKS 264in/272ex cams coming next)
So with my current setup plus the injectors, evo 3 02 housing, cams, and intercooler sprayer it should add a good amount of horse to my current setup. im tuning for 400 whp.
The Ntercooler kits are not as picky as the standard wet kits. You dont need to purge, and you dont really need a bottle warmer. Slap a gauge on the bottle valve and maybe a remote bottle opener and call it quits. You have a very good set-up. I would seriously recommend a wet kit. A 50shot will give you almost 100HP. With everything you allready have done to your DSM, I just dont think you will notice any gain from the Ntercooler kit. Just my .02 cents.
