Next turbo upgrade after 16G?
truwarrior
1,422
6
Dec 19, 2002
My motor's stock and I'll trying to find out what turbo I can upgrade to without having to build the motor and still have good street spool? 18G worth it? I love how the 16G performs in the winter, ie 40-30 degree out but I'm not to happy about the summer performance. I have water injection and HAHN FMIC. Any sugguestions welcomed.
A 20g would be a nice upgrade, still spools faster than some large Garrets that flow teh same air and bolts to a stock manifold. Great turbo IMO, although the technology is considered "old" by some
And yes, make sure you have the fuel system to suppport a larger turbo, but if you've ran your 16g to where it's just not enough anymore i would imagine you have a decent fuel system already, but i haven't looked in your profile to see.
A 20g is a nice turbo wih WI and an FMIC. It allows you to start building really good street power (400 hp range) while still having stock internals
Great things with a 20g:
Cams
A little headwork to allow you to rev higher
At sometime, maybe new intake mani, but not required.
You can end up wirh a really nice balanced street engine, with a lot of power.
Jason
20g or FP Green, or even a FP3052 or same size BW turbo. My buddie has a Green and loves it. Street car with 272's 720cc's and eprom with safc made like 360 on ca pump.
I was thinking a 20G aswell. I have a 190 FP and 650 PTE injectors. Will that be enough fuel? I know my 190 FP was running a little low towards redline with 20psi on the EVOIII.
Would CAMs be worth it if I'm not looking to build the motor?
Also since I'm FWD, I'm trying to find a balance of good power band power and spool vs slow spool and max HP. No point in having a dog of a car till 4500 rmps then having no traction when the turbo hits! I do have a EBC which will allow me to switch between high and low boost. I guess ultimately I want a turbo that I can lower and control the boost in 1st and 2nd, then have enough power in 3rd but not enough to loose traction. Right now I can usually pull all the way thru 2nd if the ground is flat and dry with minimal spin, but 3rd gear is kinda boring so to speak...
Cams are worth it. With or without headwork.
650's are fine
The 190 fp is probably ok, but for a few bucks, go to the 255. It will do you for a 20g turbo with headroom.
Yes, the 20g physically can not spool like a smaller turbo, you'll barely notice it the 1st day, then love the fact that it will just pull all the way to redline.
The Big 16G, 18G, and 20G compressor wheels all have the same size exducer so, theoretically, spool times should be relatively similar as long as you're using the TD05H turbine.
I would never pay money to "upgrade" from a 16G to an 18G....it would have to be 20G or bigger to be worth it.
I have FWD and sometimes its a little better to have a turbo a little on the slow spooling side, it tends to help with traction. If the turbo hits to hard you'll break loose before you get moving and end up spinning a little more (of course it's kind of a fine line) I have a 57 trim and it hits about 4200-4500 and it did help a little bit in 1st gear to have some lag, but if i still flat shifted into second the tire grabbing pavement game was all over with :) I ended up getting a quife LSD in the tranny and that's done wonders for me. When i dyno'd 332 on pump it was actually sticking the tires almost completely through 2nd instead of cooking them. But now i've gone to E85 and 25-30psi daily so i'm kinda playing the same game with traction again, but these higher boost areas are where i can really tell that the lag seems to have some positive value at times.
I myself am wanting either a 20g or H1C so i get a little spool back and can still make near the same power on my setup. Now that i have traction, i'm after the broadest powerband i can get.
^^^Yes!
But if a proper turbine wheel is installed. . . OP which 18g are you wondering about?
What are your goals? A cam tweek can yield a more linear powerband.
The hx35 or big h1c is of course what I personally would recommend if you're looking for 450-500whp. Mine spools as fast as my small 16g (not a typo), so street manners are very nice.
