DSMTyson
- 1,225
- 10
- Nov 9, 2010
Lake Charles,
Louisiana
The stuff in this post was solved(had to enable the idle switch simulation), now i need help for the stuff listed in my last post toward the bottom.
You got to set up the maf to run as good as you can . go for a short drive. stop the log right click on it and select the maf adjust and then of course save to ecu.this should get you started.
then set the airflow per rev to around .25 by moving the maf adjust sliders up or down.(the first to dots are used at idle)
Post a log.
If you don't know how i can help
Hit the start capture instead of the start stream.
I was going to post one of the previous logs i managed to save before i started having the issues, but the site says that "the file exceeds the quota by 243KB"?.
double check the maft setting on link and leave it on stock 2g maf not hacked at the moment also double check your engine bay for anything that might have came loose intake, piping, vacuum hoses etc..... maybe during the pulls something came loose......
.First off your target idle is set to high, your idle switch isn't working so enable simulate idle switch from TPS.
you also want to log combinedFT, also your front O2 isn't cycling like it should (not working?)
Follow this demo http://www.ecmtuning.com/demos/initialsetup.html
should get you in the ballpark and report back with another log
) It does it at idle and whenever i let off the gas under 45mph it seems.Your 02 doesn't look like it's even trying to cycle . i'd check it and change it, if necessary. and your injector settings are set for 565 cc but your mod list says 550 cc make sure they match.
Stupid question is the throttle cable holding open the throttle open abit?
Have you played with the throttle plate adjustment or the biss(idle screw)
Check to see if the tb has a big leak by spraying something like brake fluid or even water on it.it should change the pitch of the motor if it has a leak.
